Author Topic: Vintage Enfield pics.  (Read 513 times)
James.
  • Independent.
on: December 19, 2022, 10:41:25 am
Just love these old vintage motorcycle images.
Still a similar image to the modern classic.
« Last Edit: December 19, 2022, 10:52:25 am by James. »
Freedom.
NVDucati
  • USA 2020 INT
Reply #1 on: December 19, 2022, 11:49:20 am
Member: AMA
Current Rides: '14 DL1000 ADV, '06 SV650N, '93 900CBRR, '74 Ducati 750GT, '06 ST1300PA
NVDucati
  • USA 2020 INT
Reply #2 on: December 19, 2022, 12:29:43 pm
There was another ad that caught my eye because it boasted about the Royal Enfield "Automatic Neutral Finder".
I might be the last to know about this.
It is explained here: https://www.royalenfields.com/2017/06/in-praise-of-neutral-finder-on-four.html
Member: AMA
James.
  • Independent.
Reply #3 on: December 19, 2022, 02:04:34 pm
I had the neutral finder on this 2006 RE bullet 350cc.
Discontinued in 2010.Pity it was a good practical feature.
« Last Edit: December 19, 2022, 02:20:40 pm by James. »
Freedom.
Richard230
Reply #4 on: December 19, 2022, 02:12:51 pm
I have been aware of that neutral finder since I first read the referenced Cycle World road test. But what are "optional cooling discs"?
James.
  • Independent.
Reply #5 on: December 19, 2022, 03:03:08 pm
I am guessing this may have been a reference or description to the change from drum brakes to discs on the first disc brake bullets.
Freedom.
Richard230
Reply #6 on: December 19, 2022, 03:47:45 pm
Did RE have disc brakes available in 1966? if so, that would certainly be news to me. The first time I ever saw a production motorcycle with disc brakes was the 1969 Honda CB750.  ???
Adrian II
Reply #7 on: December 19, 2022, 04:07:03 pm
Optional Cooling Discs: I think that by that they mean the "bacon slicer" alloy trims fitted to the front brake drum as a cafe-racer accessory.
https://accessories.hitchcocksmotorcycles.com/20459
NVDucati
  • USA 2020 INT
Reply #8 on: December 19, 2022, 04:13:45 pm
Member: AMA
James.
  • Independent.
Reply #9 on: December 19, 2022, 05:38:43 pm
The first disc brakes (front only)on a production bullet was 2009 according to wiki.
Freedom.
Richard230
Reply #10 on: December 19, 2022, 10:12:28 pm
Now that makes sense. No doubt installing bolt-on discs to a brake drum is less expensive than manufacturing them with larger cooling fins. Plus, that allows the owner to make the wheel heavier for better road-hugging weight and gives them something extra to buy from the factory. A win-win.  ;)
« Last Edit: December 19, 2022, 10:15:14 pm by Richard230 »
Adrian II
Reply #11 on: December 20, 2022, 01:49:24 pm
Technically it was the Electra-X, 2004-8 as far as export models were concerned. First RE factory accessory disc brake kit was offered around 1991, the last home market 500 E/S Iron Barrel Bullets also had them as standard. Other Indian market 350s such as the AVL Thunderbird and Machismo (great name, huh?) were disc brake from 2004/5.
James.
  • Independent.
Reply #12 on: December 23, 2022, 03:09:00 pm
Old school.
Freedom.
AzCal Retred
  • Chennai Wrencher
Reply #13 on: December 23, 2022, 04:39:49 pm
@ #10: "Plus, that allows the owner to make the wheel heavier for better road-hugging weight and gives them something extra to buy from the factory. A win-win."
Yup, road hugging weight for sure. Maybe the holes are supposed to emit a shriek when "at great speed" like Stuka dive flaps, terrifying anyone you are overtaking?  ;D  I've always wondered about those bacon slicers...steel?...to radiate away heat? Copper plating the spokes would likely do a better job. I like BW's use of the "Holy Drum" 1950's hot rod technique myself.
Bilgemaster
  • Just some guy
  • Global Moderator
Reply #14 on: December 23, 2022, 06:33:56 pm
Winnie: Queen of the Desert
More Info Here:  https://thevintagent.com/2022/01/20/winnie-queen-of-the-desert/
