"Your wideband sensor won't last long here. It needs to be installed at least 50cm away from exhaust port. It's a lot more fragile than a narrow band O2 sensor.
That's the reason why I installed it behind the Brake."
You might have a different product from the US version. Here's from the manual:
"...it’s recommended to position the weld bung/sensor approximately 6-inches from the exhaust port on the respective cylinder you wish to tune."
Dynojet support was very supportive! I asked about the placement on my header. For HD big twins, they recommend 1/2" from the head. So the answer was mine would be alright.
Yes, it's surprising but it worked just fine.
