Also has anyone found a good stabilizer for the front? When my bro did a shake down run he hit over 100 pretty easy and it was a little twitchy in his words.
Oh and I will be visiting him and getting some juicy mods later this spring when the weather is better -- I'm just letting him beta test everything.
Tell him to torque the steering head bearings to about 16-18 Nm, stock torque is 8 Nm. And if he hasn't already, ditch the stock tires. The front end will be transformed.
When you said ECU, do you mean he got a Power Commander, or something else? With a big bore kit he really needs to have his bike dyno tuned by someone who can crack the stock ECU and write a new map. The advantage of doing it that way is that ignition timing can be optimized and each cylinder can be tuned separately, which mine needed. I have a guy in NY State, but that's a long way from Montana. I have the high compression 650 kit and the Hitchcocks stage II cam and headers, S&S pipes, etc.
A PC cannot adjust timing, or each cylinder, and frankly my tuner found it impossible to make work, as it seemed to have some serious, and probably lawyer induced, limitations on it.
Unless you're drag racing and need WOT performance all the time, you probably don't need bigger injectors. And if you do, then you'll probably want a ported head with bigger valves too. The rabbit hole gets deeper. Revelry Cycles in Australia makes both the head and bigger throttle bodies, and then you get to start from scratch with tuning. And now your rabbit hole looks like a pyre where you get to throw all of your money and watch as it goes up in smoke.
