For me, the rear brake is for holding the bike in one place while stopped on a slope waiting for a light, and *maybe* braking downhill on a sketchy surface (like sand on asphalt, or loose gravel).
I find discussions about the pros and cons of rear brake use get pretty theoretical pretty fast. Like someone will explain that "every little bit helps" so you should use the rear. But then ask that some person how often they even practice full effort, threshold braking from the highest speed at which they ever ride, and you get a blank stare. In my experience, on anything other that a cruiser the rear will do nothing in an emergency braking situation once forward weight transfer occurs, and in the absence of ABS it might be 1% of riders who can make effective use of the rear for that half second or so at the start of a panic stop. If you are getting alot of benefit from the rear when you are tryin to stop really hard, then you need to practice with the front more, because you are not using it to full effect. Get the front howling and squirming while slowing down from 70 mph, then tell me what the rear is for.
Maybe ABS changes the above calculus, but I doubt it, at least not on dry pavement. Pretty sure an INT650 will lift the rear wheel before front ABS kicks in.
When it comes to using the rear for performance riding to stabilize the bike on corner entry etc etc...okay, maybe. But that's above my skill level and I have ridden well enough to win some club-level races. Not sure what application it really has on the street, where it is unusual to make use of more than 60% of what the bike can on the track, in terms of cornering.
Change my mind.
