With a multimeter, check the correct operation of the TPS sensor even at the maximum opening of the throttle valve
Also check the error log stored in the ECU memory
I tested the tps operation last week and it all seemed to work as it should, I thought the values were a bit low on full throttle but I think that was due to a flat battery and/ or crappy multimeter.
As for the error log there were 4 codes, I couldn’t figure out one of them but the other 3 were oil temp, tps and cps sensors, I’m not sure when they were triggered so I cleared the codes and took the bike for a decent ride trying to get the codes to pop again and they haven’t yet.
I have the RH crank case off atm just waiting for tools to remove the rotor so I can inspect the woodruff key, also picked up a new multimeter, I’ll test all electrical components tonight and report back.
