Royal Enfield Motorcycles => Bullet Electra & AVL => Topic started by: luoma on August 10, 2007, 03:23:29 am
I have the classic exhaust from the CMW performance kit and am thinking about drilling out the baffle for more noise. I like a good loud bark out the tail pipe, but am concerned about altering performance in a negative way. I have drilled a few tiny holes already to help lean out the mixure (new carb ran way too rich).
Have your way with it. Drilling out the baffle will increase flow some and may in fact be a good thing. The key is to make sure that you re-jet the carb when you have settled on a configuration
Thanks, I think I will open it up a bit more. Even with no silencer, these bikes are not as noisy as the custom V-twins roaring up and own the road.
I think I've got the carb just about right. When I first installed it, it was very rich, si I moved the clip on the needle one notch. That seemed to help, but the plug was still a bit sooty, Not enough however to move the needle another notch, so I put a few 1/4" holes in the baffle by going in through the inlet side of the silencer. It's still pretty quiet and the plug is cleaner.
