The piston failure. Why it should size i don't know. Gap was pretty big, about 0,1mm...don't have the exact material specs though.
I know why.
The piston/cylinder clearance was not big enough for a forged piston.
Forged pistons are denser material which causes more thermal expansion than cast pistons. Also, some cast pistons have silicon content in the alloy which reduces thermal expansion.
Bottom line:
You need more piston/cylinder clearance than 0.1mm.
Without actually measuring the piston, it is hard to say exactly how much, but my experiences with forged pistons in the 535 show need for at least .005", and maybe even .0055".
But if you go too much, it will have some piston slap on cold starting, which isn't really harmful, but sounds bad.
Most of the time, .006" clearance is too much and might slap.
