I agree that by 1980 motorcycle manufacturers had figured out disc brakes.
And I wonder if it's fair to say that development and improvement of drum brakes hadn't stopped about 25 years before that? It seems pretty obvious, when one looks at the the drum vs. disc assembly, and counts the components, one seems clearly cheaper to manufacture than the other.
I think one truth is emerging from all this, that the Axeman ends up pushing his machines more than most of his friends. He's been in situations where he weighed the time it would take to dismount his front caliber to eliminate its drag, vs. the miles of remaining distance to push, and factored in the ambient temperature, while mentally kicking himself for not ordering replacement pads from India three weeks earlier instead of just last week.
When I'm pushing bikes onto a pickup truck, which happens a few times a year, I prefer to put the machine in gear and use the clutch as a "reverse brake". This acts as a dead man brake, so if things go south, engine braking is ON while hands attend to more important matters. My buddies and I don't seem to have much interest in short stroke, multi-cylinder bikes, so engine braking has always been adequate for control so far.
The rear brake pedal is available to the man on the right, so each guy gets the means to arrest motion. There's always that moment in the process, where the front wheel is on the bed, the rear wheel on the ramp, and the bottom of the engine is hitting the end of the ramp when things get uncomfortable. The front wheel is unweighted, because the engine is scraping, and the bars are pretty much out of reach of both men, until somebody climbs aboard. This may be why pros use tilting trailers, lift gates and other, expensive stuff.
It's interesting to see what has happened with pedal mountain bikes. Although the various forms of rim brake, win the "torque per pound of components" fight hands down, because they are act directly on the rim, discs were developed and were favored for a time, but the most recent developments are forms of drum brake including something called a "roller brake". Shimano has provided easy integration of their roller brake into many of their hub designs.
