OK! I promised a resolution summary, and here it is:
First, let me share the convenient, face-saving "Repair Resolution & Credit Therefore Rule". I established this Rule early in our (so far!) 48 year marriage. The Rule goes something like this: If something is broken and you fix it, you are not required to reveal exactly what the problem was and what ingenious steps you took to fix it. This rule is especially helpful when you fix something, but have no idea exactly what was wrong with it, and/or how in the world you managed to fix it. The bottom line is that you still get credit for fixing it, even if all it took was a swift kick to the item, followed by a few uncivil exclamations. You fixed it! You get full credit for the repair. You are not required to provide an accurate, detailed and true explanation of how you did it. Gratitude from the less skilled and uninformed family, friends, co-workers (this rule applies especially well to copy machines!) is still required, even if you keep the fix a mystery. This handy rule has saved me a lot of time over the years, and preserved my perch as the Premier Repairman of the family I hereby invoke the "Repair Resolution & Credit Therefore Rule" regarding this post and problem.
I FIXED IT! I ran a number of tests with a multimeter on each associated circuit and part, and all results were within normal ranges - no voltage drops, resistance, or continuity problems. I tried disconnecting the sidestand switch, but this had no effect. I inspected the condition, cleanliness, and tightness of all the connections involved; all of which were in good order. I tested the battery voltage under load. None of these interventions proved effective. No clicks, no buzzes, no sparks or smoke, no start.
Beginning with the starter motor, and working back through the entire system, I disconnected, inspected, cleaned, and re-connected every circuit, switch, relay, and fuse on both positive and negative sides. When I was done, I went back through and re-inspected every connection. Then, I walked to my other bikes, and loudly praised them for their easy starting and high reliability. I then buffed them gently with a soft microfiber, and loudly admired their ruggedly handsome good looks, and awesome speed and handling. Meanwhile, the errant Bullet took all this in quietly and stood off by himself, smudged from the recent repair efforts and cold as a glacier from not starting and running.
There's a lot of other highly technical stuff I did (sticking out tongue in proper position, singing along with Lynard Skynard, and a bunch more!) but under the "Rule" I am not bound to reveal all my secrets to you.
Finally, I spit over my left shoulder first, then my right shoulder, verified that the sidestand was up and the kill switch was off, and the bike was in neutral. Then I turned the key to start, muttered a few inspirational and encouraging words to the Bullet, lightly pressed the start button, and......VAROOM! Immediate, flawless, and admittedly quite exciting start! I shut the bike off, waited a couple of minutes, and ROAR! He started smoothly and instantly. Over the next few hours I returned at different intervals and was rewarded by immediate and strong starts each time. I FIXED IT!
I have told you all you need to know about my success. If you have any questions, don't bother, as I have invoked the "Rule" and I have no intention of revoking it. I hope that forum members will find this post especially helpful. Stay tuned for my next highly informative "I FIXED IT!" tutorial, and thank you for your suggestions and interest.
