Author Topic: oil sump screen maintanance  (Read 9860 times)
Dr Mayhem
on: September 06, 2019, 08:35:54 pm
Apparently a guy bought a Interceptor in Scottsdale AZ this past May and rode it for 13,000 miles around Mexico till the motor starved for oil and locked up.
It was Scottsdale who replaced the motor so they know firsthand what happened
He hadn't done a single oil change or any maintenance on it. The sump screen had plugged causing the problem. So, it seems important to change/clean that screen as indicated
I don't have the manual open and I don't remember exactly what the exact maintenance schedule is for that screen now
« Last Edit: September 11, 2019, 10:59:02 pm by Dr Mayhem »
Guy
19 Conti GT in Dr Mayhem paint 08/24/2019
06 HD Street Bob
04 Buell XB12S Lightning
Roshiba777
Reply #1 on: September 07, 2019, 07:49:57 am
You have to replace the screen at 10000 kms
Royal Enfield CI 500 (2000)
Royal Enfield STD UCE 500 (2010)
Royal Enfield Classic 500 (2011)
Royal Enfield Classic Chrome 500 (2011)
Yamaha RD350 (1988)
Royal Enfield Interceptor 650 (2019)
Dr Mayhem
Reply #2 on: September 07, 2019, 03:53:10 pm
So the bike went over twice the miles before a problem, and no telling the clutch abuse!
Also, should be less junk coming off the clutch after the first screen change? First screen change being critical!
Guy
06 HD Street Bob
Dr Mayhem
Reply #3 on: September 11, 2019, 11:10:05 pm
Kinda funny story from 1978 Klamath Falls OR. Little shop on S. 6th sold Kawasaki, Suzuki, KTM others
They had a new KZ 550 that sold three times in about three months. It would loose significant power when it was up to full temp and nobody couldn't figure it out.
Finally given the go ahead to tear it down they found a red shop rag neatly folded up between the oil pickup and the pan bottom.
Bike was finally sold for a fourth time to a happy owner, LoL. I guess they are a full roller bottom? Disgruntled Japanese worker?
Guy
06 HD Street Bob
GSS
Reply #4 on: September 12, 2019, 04:12:45 am
I cannot find this screen listed on the maintenance schedule and you would have to remove the entire oil pan to get to this. It seems unlikely that this needs routine cleaning otherwise we would be pulling these out of modern car and bike engines every year. Is there a link that anyone can share for the RE recommendations?
« Last Edit: September 12, 2019, 04:16:29 am by GSS »
2022 Continental GT 650 Dux Deluxe
2019 Himalayan Snow
2019 Interceptor 650 - Chrome...off the first boat!
Previous REs:
2021 Meteor 350 Supernova Blue
2014 Continental GT 535 - Red...lowest VIN off the first boat!
2010 Classic 500 - Teal Chrome
Dr Mayhem
Reply #5 on: September 12, 2019, 04:06:23 pm
Your logic is flawed! there is a clutch shedding junk all the time in this oil supply unlike what you mention
service manual page 30!
clean at 300 miles, then every 6,000 miles thereafter
Most likely a plastic part with a plastic screen so I'd keep one on hand in case you find a hole in it. Probably not expensive anyway!
you unscrew a few bolts, pan drops down between frame rails, do your service & reassemble
« Last Edit: September 13, 2019, 12:19:23 am by Dr Mayhem »
Guy
06 HD Street Bob
Dr Mayhem
Reply #6 on: September 12, 2019, 04:21:06 pm
keep in mind these motors are all plain bearing bottom end!
also, this will be a pretty fine screen to protect pump and pump bypass seat.
if that pump bypass valve was to stay open from a caught piece of junk your motor is toast  :)
Guy
06 HD Street Bob
Dr Mayhem
Reply #7 on: September 12, 2019, 04:49:18 pm
member here 'western cycle supply has these screens for $5.99
https://westerncyclesupply.com/oil-strainer/
Guy
06 HD Street Bob
Enfield Pro
Reply #8 on: September 13, 2019, 02:31:52 am
Somebody stole one for $5.99, they should have been listed at $9.99! Way to sniff out a deal Dr. Mayhem.
Tim
2009 G5 Military W/Sidecar
USCA #9136
REOC Member
Dr Mayhem
Reply #9 on: September 13, 2019, 04:35:33 pm
Will you be stocking the pan gasket 575041C also?
the shape of this gasket looks like it could be of a steel shim material and also double as windage control?
« Last Edit: September 13, 2019, 04:47:43 pm by Dr Mayhem »
Guy
06 HD Street Bob
Enfield Pro
Reply #10 on: September 13, 2019, 06:00:37 pm
Does a bear s**t in the woods?!? I have 5, they aren't listed because I don't have a suitable photo. I admire anyone that makes a living in Photoshop!
If you must have one NOW let me know and I will turn it on.  ;D
« Last Edit: September 13, 2019, 06:03:46 pm by Enfield Pro »
Tim
USCA #9136
REOC Member
Dr Mayhem
Reply #11 on: September 13, 2019, 06:05:46 pm
Does a bear s**t in the woods?!? Of course I'm going to stock the gasket. I have 5, they aren't listed because I don't have a suitable photo. I admire anyone that makes a living in Photoshop!
Please!.. I'll order one and a few other items also. I see it's only a regular paper gasket with a complex shape
Guy
06 HD Street Bob
Enfield Pro
Tim
USCA #9136
REOC Member
Enfield Pro
Reply #13 on: September 14, 2019, 02:57:22 am
2 strainers left, if you want one  get 'em while I got 'em! The next batch won't be in for some time, probably around Christmas if I had to guess.
You can find them here
Tim
USCA #9136
REOC Member
GSS
Reply #14 on: September 14, 2019, 04:57:02 am
I know why I missed seeing this....the part is buried on the same line on page 30 as the magnetic drain plug.
In any case it is just a clean and reinstall part....no need to buy or replace this every 10K as was posted by someone. Pretty inconvenient to remove the damn oil pan though.  Will see what this looks like at my next oil change and decide on future frequency.
« Last Edit: September 14, 2019, 04:59:52 am by GSS »
2019 Himalayan Snow
Previous REs:
