Here's the issue, (if theres a thread somewhere that may be of help chuck it in, and bear with me, I can be a bit special)
While ago the regulator was on the fritz and killed the battery that was in the bike. It got left for a bit until I got a chance to have a poke around. There was also nothing happening with the fuel pump and nothing on the dash when the ignition is turned on except the Neutral light. The bike tries to turn over but it wont start.
That Ive replaced the regulator and battery, and all the fuses are A-OK, but still no changes on the above issues.
Looking around the web, seems relays can be a plague on these, I'm wondering if the relays are kaput, or perhaps when the bike wasn't regulating itself perhaps the ECU may have taken a beating.
Or if anyone else has any bright ideas on stuff to check it would be greatly appreciated.
Also, Ive checked the obvious, wiggled all the connectors for anything loose, side stands not it, and kill switch isn't either.
