General Discussion => Tech Tips => Topic started by: abstruse1 on December 02, 2013, 01:36:23 pm
Title: Tweaking ECU?
Post by: abstruse1 on December 02, 2013, 01:36:23 pm
I have a 2014 RE and it seeems to run a bit lean across the board, mainly noticeable just off idle.  Short of installing a Power Commander. is there any way to richen the mixture a bit, e.g. by tweaking the output of the O2 sensor or upping the pressure of the fuel pump?
Title: Re: Tweaking ECU?
Post by: ROVERMAN on December 02, 2013, 02:11:57 pm
I would wait until full break in (at least 1,000 mi?) before attempting any tweaks. My 2013 B5 is also a bit fluffy off idle. I gather from others on the forum that the TPS voltage is the critical element, search the site and brother Singh's video library.
Roverman.
Post by: abstruse1 on December 06, 2013, 04:25:21 am
Probably good advice.
How about plugs?  My bike came with Bosch Super R6.  I've had a bit of trouble crossing this to a NGK (or other) plug.  Some recommend their BPR6ES or the BPR7ES, citing a number 5 -- hotter -- as stock.  I'm not sure why a colder plug would help roughness or lean-like symptoms.  Maybe the -6 or -7 recommendation was for a different RE.
Post by: baird4444 on December 06, 2013, 01:25:22 pm
I may be talking out my arse but I seem to
remember that when this new motor 1st came
out the answer was to put in the Iridium plug...
           - Mike
Post by: heloego on January 21, 2014, 02:44:41 pm
It's a toss up here between the BPR6ES and the BPR6EIX (iridium). Some prefer the iridium. Some don't. I'm happy with my iridium.
