Been working on this G15-CS over the past few years...finally fairly road-ready...shortest story is I got it from the original owner in a kind gesture. Ran when parked after a minor refresh in the 90s. Mag wasn't sparking, clutch had some issues, and a few other things stood in my way when I got it into my hands.
Significant work done so far:
-Got the mag refreshed with an Easycap
-Got the ceriani rear shocks rebuilt
-Got the Monoblocs sleeved and rebuilt them
-Reversed the shift pattern to match my 1-down-on-the-right Enfield
-Installed a Bob Newby belt drive and clutch (with some modification to the primary to allow better mag access), which was easy except for needing a spacer for the outer primary cover
-Rebuilt the fork with Lansdowne cartridge dampers, fresh stanchions, and JSM turcite bushings
-Swapped the timing cover for one with the tach drive oriented vertically; previous owner had swapped for one with the high-pressure feed to the head, but the tach drive cable was pointing right at the pipes and running hard over them
-Got the tach unfrozen and rebuilt the drive unit using epoxy over the covers which previously liked to expel gears at high RPMs. Also frankensteined together a working speedo drive.
-Swapped out the stock air filter cage for some Unis
Just re-timed it to 28 degrees (vice stock 32) because I confirmed it had high-compression pistons. Much snortier now. The mag is cool, but was a real pain to access for adjustment; less so now with my dry primary into which I cut an access port to the front of the mag. Less need to remove either the inner primary or the mag from the bike for most work. Alas, still need to open the timing cover to re-set the ATU on the taper if you have to do any real timing adjust.
Trying to keep the bike as rideable as possible without messing up its classic-ness. Love the way it feels on the road...heavy center of gravity down low almost feels nimbler than my Enfield. Little gutsier than my Fireball, especially with a passenger, but the little Enfield would give it a run for its money. Brakes lead something to be desired and I might convince myself to put a TLS plate up front.
(little more of a write-up of the work here:
https://www.dotheton.com/index.php?t...-g15-cs.77009/ )
