Not an iron barrel, but my '08 AVL's primary case is vented out the top into a small hose that used to go to "the can". All that stuff is gone now & I turned the elbow forward & ran the hose down between the case & the starter motor & cut the excess off. Maybe some day I'll tap the hole & drill a small hole in the plug. Back in the day when some engines & the primary cases shared oil (stupid idea), there was a small vacuum on the primary case to help reduce leaks at the gasket.
