I destroyed the graphite gasket, but TEC promptly sent another at no charge. Put a little grease on the graphite and your assembly will be a lot easier. Once assembled, I have no complaints. The weight savings is impressive, and it sounds great. I don't think the finish is all that bad, and I like the bronze-ish color it takes on. You already know it is affordable. I added a K&N air filter when I installed the TEC exhaust, and I feel like there is a little more mid-range pull. I fully acknowledge that this may just be psychological because it is louder.
