Thank you. Has anyone been told otherwise from either manufacturer or licensed retailer? That does count for something, no?
Yes. From Robert Taylor from KSS and from Tec Bike. Both are YSS suppliers, Robert Taylor is a highly regarded suspension tuner.
George from Tec Bike: "The YSS full kit does not say to do this, but I disagree and think they are trying to make it look easier to install, but will never work as well in high speed compression"
Robert Taylor from KSS: "The other 50% of the issue (aside from progressive springs) is poor hydraulic control (damping) This is a reality that many users totally fail to grasp and concerningly also dealers and their wet behind the ears counter sales people. There is almost always a preoccupation for easy sales and quick profit rather than doing what is right. I have been constantly in this industry now for 45 years and counting so please excuse my cynicism. Simplistically, think about damping as controlling the rate of change of fork position, damping if properly calibrated will slow down fork movement so it is more controlled. The brutal reality is damper rod type forks ( such as these ) produce an abysmally poor level of initial damping and brake dive resistance, explaining why they are initially sloppy in action. BUT ALSO, they produce too much high speed damping, explaining why they don’t ride abrupt bumps very well, exacerbated by the initial low velocity inclination to blow through their stroke and precompress the springs. Its all about snatching defeat from the jaws of victory."
By simply dropping emaultors on top of the unmodified damper you are only adding some low-speed compression damping. The restriction at high flow rates remain and the fork will continue to be harsh.
If you buy the YSS PD valves separately, you get installation instructions on enlarging the damper ports:
