It will require a little bit of modification and a different rear fender, but is doable. There is a bit of a structural bump in the fender and wiring under the rear seat.
Same. When swapping out seats i was a bit disappointed to see it not very "clean" under the pillion. I have seen some aftermarket luggage plates that cover it with some taste (Bandidos Pitstop in India, maybe? Memory fails...)
Probably the forthcoming 'Classic' version of the 350 Meteor will have the look that you want as it will leave the factory with no rear seat fitted.
In my opinion, this one would better fit to the vintage look of the Meteor:https://youtu.be/WgcezleFw1s
