I just reviewed the video where I found the info about the wheel bearings...seem as though they were replaced at 9000 km.
The bike sure looks fabulous though!
For folks who might not be able to convert kilometers into miles, the front and rear wheel bearings on this man's Interceptor were replaced at around 5625 miles. He says that the bearings were cheap, I assume when he says "600 bucks" in the video, he is referring to Indian Rupees which would translate to about $8.50 US dollars.
One thing that might be something to consider is that this fellow says he booked his bike very early after introduction, so perhaps the bearing issue was worked out, or is an isolated incident. This guy also talks about the head bearings being an issue, which, as I recall, was also an issue on the early Himalayans.
Going back a bit in history, Pete Snidal says in his book that the India made Bullets used low quality bearings and that they should be replaced when possible with good quality, Swedish, English or US made bearings. I can say that I pulled a rear wheel bearing out of a 1999 Bullet with around 11,000 miles on it, that was toast. To me, a wheel bearing isn't that big a deal, easy to get to, and likely to make it's demise known by various signals. I'd be more concerned about the possibility that low grade bearings might be inside the engine casings, where they could possibly do some real nasty, expensive damage before being discovered.
