I found the attached image on a thread in another forum regarding RE UCE engine transmissions.
If this diagram is correct, I wonder why RE chose to have so much movement of the sliding gears. Downshifting from 5th to 4th involves pulling the 2nd/5th sliding gear out of engagement on the output shaft, then pushing the 3rd/4th slider into engagement on the input shaft.
I guess it's inevitable to require 3 sliding gears for 5 speeds with the input / output shaft gearbox, and the designers just have to choose which ratio transitions involve moving which gears.
The animation in this video uses an alternate arrangement, but might be helpful for those who are having a hard time understanding how the transmission works.
https://www.youtube.com/watch?v=g8xnIFf4id4This arrangement seems more straightforward to me, with 1rst getting its own slider, 2nd / 3rd sharing a slider, and 4th / 5th sharing a slider.
I wonder if any of our members has insight into why RE chose the the design they did? What advantage does it have? Or does the arrangement facilitate the flat disc shifter cam, rather than a drum type?
The shifter mechanism can be seen here:
https://forum.classicmotorworks.com/index.php?topic=20090.msg221090#msg221090
