This is what I'm puzzling about.
Brake rotor side to sprocket side...(right to left)
1) About 1.5" long steel spacer on the outside of the bearing that contacts swing arm.
2) Bearing (#6203)
3) Long spacer that goes bearing to bearing and is about 3 mm longer than where the bearings seat in the hub. (86.5 mm)
3) Middle bearing (#6203)
4)
GAP of about 3 mm5) Sprocket spacer
6) Sprocket bearing (#6205)
7) Short fat aluminum spacer that contacts the left swing arm.
When you torque it down, the middle bearing appears to float because of the gap and too long spacer.
The sprocket side bearing is crushed against the cush rubber but it's much larger than the other 2 bearings, so presumably heartier.
The brake side bearing is the most vulnerable since it takes the 52 ft/lbs as well & is smaller.
This is my 1st bike.
Am I missing something?
My assumption was that there should not be any gaps in order to avoid side forces on the bearings.
Additionally, I'm predicting all bearing failures 1st appear on the right side.
My 1st indication something was wrong was a dragging rear brake.
Turned out it was dragging on the caliper frame.
If all the above is true, rear wheel torque is critical and should not exceed 52 ft/lbs (my guess is 45 is good or at least that's what my elbow likes
