First post here. For what it is worth, I have replaced my Meteor's stock mirrors with a pair of CRG Blindspot mirrors, mounted under the grips and oriented inboard. I wanted a low-profile look and to avoid a typical bar-end setup. I found enough space to clamp the mirrors by moving the controls and grips inward by 10mm on each side and kept the stock bar end caps. The CRG mirrors, admittedly smallish at 2", have excellent optical quality replaceable glass. Properly aimed, they provide all the essential information I need.
