Normal O ring, X ring are too wide for uce. I fitted a DID O ring and it wasn't till I removed the case to change sprocket size that noticed the chain had been rubbing on the crankcase and was pushed hard against the inside face of the sprocket. I don't think it would ever wear right through the case but it was enough show wear on the inside of the sprocket. Chain run was fine and wheel alignment spot on.
