Wr6133 did you fit your 535 to an alloy rod or a steel one?
Was curious as to what others are doing with these kits
Stock (alloy) rod. Head has had some love from a dremmel (nothing crazy just tidying up the factory mess) and better valves + springs. Previous owner also fitted cams but I'm pondering going back to stock on them as (I assume it's them) seem to create a bit of a "powerband", that sometimes off-road catches me off guard and results in (often amusing) loss of traction at the rear. I suspect to really wring the power out of it I need a bigger carb, current is 30mm, I would have thought 32 or 34 would be more suited though as the current has less than 400 miles use it can stay for a while. Dirt bike so I'm not chasing power figures, though the temptation to 612 is always there
More mundane stuff, boyer powerbox and ignition, oiling mods, pumps, spindle, rocker relief thingy, Samrat rockers. Next on the todo list will be Hagons on the rear, if you are going for a trials build invest in rear shocks, my 350 with Hagons is luxurious in comparison to the various stock and cheapo shocks I've tried on this one.
