I wonder how much the CG design can be stretched? 400cc? 600cc? It's a nice "clean sheet" stone axe design.
As the CG architecture is one of my all time fave vintage thumper designs, I have often wondered exactly the same thing. However, as the CG is a small displacement machine, and my personal affection for hot rod minibikes and hot rod small displacement motos is essentially unbridled, I've more specifically wondered how much the design can be stretched while remaining within the small bike category.
Calling Tom Lyons! Taking into account the above, here's an interesting scenario, then, Ace, since as far as I know you are literally the world's most knowledgeable tuner of vintage pushrod thumpers. Basically, what kind of hot rod performance could be had from this kind of engine?
Let's assume the following general guidelines:
1- A clean sheet design, or at least a mostly clean sheet design.
2- A six speed transmission.
3- Carbureted with a modern carb.
4- Air and oil cooling.
5- 300cc or so displacement, perhaps a 77mm bore and 65mm stroke?
6- Must retain the Honda CG's simple overhead valve design that uses a rocker arrangement allowing both exhaust and intake valves to be operated by a single cam; camshaft operated by a gear right off the crankshaft and low in the engine to provide constant lubrication.
7- As long as no. 6 above is maintained anything else goes, any valve angles and sizes, roller rockers, 2 valve or 4 valve head, beehive springs, exotic Ducati alloys, anything as long as the engine could still recognizably be called a "Honda CG" in name and architecture.
8- Must be a streetable hot rod engine, not just a high rpm racing engine, with enough torque for an enduro application and not just a cafe racer application.
9- Ooh, and no budgetary constraints for design, materials, or construction, smile!
For reference, here's the history of the CG engine:
https://www.janusmotorcycles.com/2019/10/22/bulletproof-the-heritage-of-the-janus-250-engine/
