Can someone confirm the routing of the rear brake hose near the shock absorber. Giving my relatively new ( to me ) 535 a once over and found that the hose had come out of its 3 clips along the top of the swing arm. It then goes over the top of the bottom bolt, but this doesnt allow it to be clipped into the clip closest to the shocker. Looks like it should go under the bolt for a straight line, but would like to check first. thanks
