Hi everyone, sorry if this has been covered before - haven't found it. Just got a new Himalayan and having serious issues finding neutral. I've owned Triumphs and Hondas for the past seven years and haven't had this much of an issue, so I'm thinking it's the Himalayan clutch.
I find neutral 50% of the time - typically while rolling to a stop, downshifting from 2nd gear. At a full stop, it's impossible to nudge from 1st gear into neutral, even if I roll the bike forward. It also won't shift from 1st to 2nd gear until I get the rpm's up to about 3500-4000. Upshifting/downshifting otherwise works just fine.
The strange thing is that when the engine is off, I can upshift/downshift through all the gears with no problem, including finding neutral.
So basically when the bike is running, the clutch issues start. Does this sound like a clutch issue or am I missing something?
Thanks in advance for your help.
