Yes, really!
The cover on my old Electra-X did exactly that, as the twiddly thingy never worked for me I replaced it with a plain tappet cover. Get one with a rectangular rubber seal and you needn't worry about using a gasket. Remove the now redundant cable and feeble plastic lever from the l/h switch cluster, more weight saved! If those bits go, you can lose the top-hat collar off the exhaust valve lifter too, it's held on by a circlip.
