Royal Enfield Motorcycles => Bullet with the UCE engine => Topic started by: bergerac on January 05, 2013, 01:43:17 am
G5 attempting to fit bar-end mirror throttle side handlebar. Using correct size allen-key and hammer/long bar cannot shift it, that allen key is in there real tight. anyone else have problems ? Larry
Dunno if it helps, but my B5's bar-end weights were held very tight - there was a heavy application of some sort of thread-lock on the allen screws, which was hard to break, and even after I did, the screws backed out quite hard all the way. I was a little concerned about stripping something, but the replacement screws went in just fine...
They're held in with red Loc-Tite, it takes SERIOUS torque to get them out. You can try tapping with a hammer or some heat from a torch or heat gun to soften it. I just went with a ridiculously large wrench.
Thanks Mattsz I'd better eat more spinach like popeye and try again!
Thanks Scott, I'll try again
