I've had luck sealing the exhaust using the chromed steel finned 1 3/4" "Exhaust Pipe Cooling Ring"; Hitchcocks PN# 26281, and a twisted loop of #10 fine stranded copper electrical wire. I put the cooling ring on the pipe, secured the pipe, twisted the wire around the pipe between the ring & the head, then tapped the ring up against the flat face of the exhaust port. I cut the "tail", the twisted portion of the copper wire, to about 1/2", then aligned it with the open split of the ring. The stranded copper seems to fill irregularities adequately and really restricts the amount of blowby, absolutely better than the plain pipe. Sealing a plain straight wall pipe into a straight wall hole seems doomed to fail, you'd need some sort of packing/gasket material and a way to secure it; the OEM installation has nothing. The cooling ring gives you an adjustable backstop, and the fine stranded copper wire has enough "smoosh" to take up the gap. The steel ring has held up well as opposed to the alloy ring which blew up on the first tightening. The Bullet isn't exactly a featherweight racer, so steel is good enough for me and my 24 BHP iron steed.
