Excellent video..
In actuality , what happens to that flyweight and pin mechanism when it is rotated at low rpm's on the cam spindle , the flyweight does NOT stay activated or IN towards the center of the Cam gear. .... It flomps in and out , activating and deactivating that pin in the base circle of the Cam. It is a hit and miss affair. As the nose of the Cam is pointed down or heading to the 6 O'clock position , the flyweight drops towards the center and flips up the pin in the base circle. And as the nose of the Cam starts heading towards the 12 O'clock position , the flyweight moves OUT and away from the center of the Cam gear flipping that pin back below the surface of the base circle. It is as much a TIMED event as it is anything else . However ... it activates erratically depending on RPM . Sometimes the decomp pin is UP in time to hit that wheel of the lifter and sometimes it comes up after the lifters wheel has already gone by it. But the next time around it may hit it ?! Whack !..... whack !.. whack ! ........... whack !......whack! whack!................. whack ! Inconsistent and unstable. The Hydraulic lifter see's this insatiability as lash and does what it is designed to do and it pumps up trying to take up the lash.... Cracking open the exhaust valve and killing the compression. It will stay pumped until it can cycle through again , without instability. Or when the rpm's get high enough , where it can keep that flyweight pinned out and away from the center of the Cam gear. But when you roll on and off the throttle , particularly at lower RPM's .... or even if your idle is a touch to low ? That erratic decomp behavior may start up again ? Is it worth it to loose compression ? Or potentially burn and exhaust valve ?
