It goes, and most importantly it stops.
Add-ons/upgrades:
1) Fly screen - recommended (it keeps cr@p of the instrument cluster, and makes a handy storage area.
2) Sump guard - recommended (it keeps cr@p off the engine). It needs holes drilling into it to stop water collecting in it after a wet ride (or wash).
3) Brembo 07BB04SA sintered pads - recommended. “SA” pads are for front applications (don’t get SP pads). Better bite from cold, better when warm, no squeaking that I can hear. A nice RED colour if you’re that way inclined.
4) Halfords 200% brighter bulb. On the fence about this one. It’s bright, but need to try a different brand to see if the high beam pattern is better (high beam leaves little light right in the foreground). Could be the headlight design - we’ll see. Workaround - hold the ‘pass’ switch when you need full illumination (foreground and background).
Maintenance:
1) Chain cleaning - Muc-Off chain cleaner aerosol (used with a chain cleaning brush thingy). Not recommended - it’s an oily chain cleaner, which gets all over everything. To get the chain cleaner off, you need a de-greaser. Sort of pointless?
2) Chain lubing - Gear oil (applied with a paint brush). Recommended. A bit of spatter after the first ride, then it does its job with no fuss. A little goes a long way. My bottle of gear oil may outlast the bike.
3) Oil changes - Motul 5100 15w50. Recommended. No issues, no noises, no clutch slip. Smells a bit ‘floral’ when you drain it (weird). Being paranoid about swarf and glitter, I did mine at 160, 360 and 860 miles. Overkill but it certainly won’t hurt.
4) Tappets - as per the service manual. Recommended. Got 99mpg on my last tank. Plenty of pull in 5th gear from 50-70mph.
4) Brake bleeding - recommended. There was the odd air bubble here and there. Bought got a random ABS compatible DOT4 fluid.
5) Re-torquing engine-to-frame bolts. RECOMMENDED. All of them needed re-torquing today (the front one was at 29nm when I started tightening it) Might apply thread lock next time.
So far so good. 👍
