Anyone who has done their own first oil change at 300 miles/500 km, has dealt with that oil strainer cover and and the messy affair that is. I'm not sure why RE thought the Meteor needed both an oil filter and an oil strainer. However, it was good to find that there was no sign of any swarf in the strainer when I checked mine.
After doing the change, I happened to notice a bolt that looks suspiciously like an oil drain bolt under the sump. It is more easily visible from the left side of the bike, as the frame on the right side hides it somewhat from that viewpoint.
It looks all the world like a normal oil drain bolt, with a large 17mm head and it appears to have a copper crush washer under it. I know RE likes to use copper for its crush washer applications. Its position is a bit odd though for an oil drain, as it is actually in the bottom of the right side engine case cover, not central in the sump. See the picture.
When I picked up another oil filter a few days ago, thinking my next change would utilize that bolt, I asked the parts guy for the crush washer for that bolt, but he could not find any reference to it. Yet, on a YouTube video seen recently, in the comments section, someone asked where he was supposed to use a copper crush washer that came with his filter. Very strange.
Has anyone removed that bolt thinking what I have been thinking? It certainly would be an easier and much cleaner way to drain the oil.
