How accurately can you drill a hole?
Redditch Bullets either have the smooth non-alternator or the early alternator "smooth bump" alloy covers.
Most classic iron barrel Indian alternator Bullets have the smooth sort Mr_84 would like to adapt.
The "bumpy" cover first appeared for right-foot shift 4 speed models on the 535 Lightning, the early A350 AVL Machismo and the 2002-only 350 Electra. Possibly the 4 speed E/S 500 Bullets too, can't remember! Check the parts book.
The bumpy cover with the hole for the left-foot shift was used on the 5-speed K/S 350 AVL models, as well as the Sixty-5 and 5-Speed Deluxe iron barrel 500s.
Then we come to the ten hole cover, the casting has provision for a left foot shift hole, though on Paul W's (originally) 4 speed right-foot shifter 350 Electra it would have remained undrilled. The same cover WITH the hole drilled for the gear shift was fitted to the 5-speed iron barrel Electra in both K/S ans E/S form, as well as the E/S 350 AVL Machismo and Thunderbird, the 500 Electra-X, AVL Classic and A500 Machismo. This sort has the alternator stator and TCI trigger bolted to it.
I get really bored tomorrow I'll try and get pictures of the lot!
