Thanks
Ill have a look at the length measurnent and post it .
I decided to use the bar ends which meant getting the right size socket the same diameter as the old grip that cane off ,i drew a circle at the end of the new grip and used a stanley blade to carefully cut out the circle ,easy .
If i had binned the bar ends and not cut a hole at the end then i would have had to trim the throttle tube and there would be a gap between the switch gear and the grip on the left sde ,this way i can still fit the bar ends and bar end mirrors .
Cheers
Dave from Scotland
