I have searched using Torch and got no where.
What I know about 'Torch' brand spark plugs is that the very first commonly-recommended way of coaxing a generator from the Far East to run better is to yank out its Torch, Bongodongo or whatever other OEM plug they came with, replace that with its Champion, AC Delco, NGK or other brand name equivalent, and perhaps then use the Torch as a fishing weight.
Anecdotally at least, with my pair of little 2-stroke 900 Watt Harbor Freight primitivo fussbucket gensets that came with Torches, I can confirm this notion. After their swap to Champions both gensets immediately began starting MUCH easier and just seem to run happier and steadier and even a bit quieter, without all the previous "seeking". This has actually been noticeable and even measurable in their far more even power output too as measured both with a digital multi-meter used to fine tune their idles under load and hence voltages, and also on board my boat with its analog AC meter for shore power. Its needle no longer sways like a metronome.
So yeah, if I had a Meteor I'd be very happy to find an equivalent replacement for a Torch plug.
