Royal Enfield brake upgrade callipers:
Standard, readily available, Brembo P4 four piston callipers with a 65mm axial mount are used in this upgrade, with the stock hydraulic line. There are 2 versions of the P4 calliper:
The P4-30/34 uses (2 x 30) + (2 x 34mm) pistons, and 2 pads for a 6.9% increase in piston area compared to stock. Not a great improvement ion piston area, but with the 3.125% torque gain with the larger rotor, EBC-HH pads, better 4 piston calliper design, and the Brembo radial master cylinder, it is a marked improvement over stock. Given street tire limitations, most riders would be happy with this lower cost approach, while high GVW, hack riders, track use, or bench racers might want the P4-34.
The P4-34 uses 4 x 34mm pistons, 4 individual pads, and a more rigid triple bridge design. Clamping force is in part a function of piston area, so not only is the 34/34 version more “powerful” but additional initial bite is provided by the 4 pad configuration. This 34mm calliper has a 20.2% greater piston area than stock. Add the 3.125% torque gain with the larger rotor and this is a significant improvement.
By means of comparison, the Beringer Enfield upgrade kit 6 piston (6 x 29) axial calliper has a 34.1% greater piston area than stock. There is however no additional torque gain from the rotor as it is the same stock 320mm diameter.
The Beringer 4 piston axial calliper (4 x 27) kit has 24.2% less piston area than the stock Enfield. Rotor diameter is the same at 320mm.
