My MK2 is just over 1 year and 4 months old and I've modified it to a retro style i like, Old-ish looks, but modern functionality.
Hers the list, in no particular order;
1. Adjustable clutch/ brake levers
2. Bar end mirror, Halcyon Style
3. Chrome headlamp bracket
4. Engine bars
5. H4 LED Headlamp bulb
6. Grip Puppies
7. Longride pannier bag frame
8. Lucas tail/brake lamp lens with LED light unit fitted and mounted on a Baak License plate bracket
9. Motogadget Blaze Pin LED indicators
10. Powerage slip-on pipes
11. Quad Lock phone mount/ charger - powered from a USB power port
12. Strato performance Air filter and air intake
13. Strato performance chain adjusters
14. Scott Oiler V system
15. Vista cruise Control
16. Oxford heated Grips
17. YSS fork upgrade kit & YSS Z series rear shocks (Fork damper tubes - each hole drilled to 5.5mm)
18. Tank Pads
19. Tank frame
20. Pressed aluminum B & W 8 x 6 license plate
