Author Topic: Valve and tappet adjustment?  (Read 2211 times)
Rad Rich
on: August 04, 2022, 06:04:43 pm
Hello again,
2017 classic chrome.  I bought with 1,200 miles 2 years ago.  I am at 4,500 miles today.  I believe I have hydraulic valves?  Do I need to do or have any adjustment to the valves or the tappets?  Just love her and want to keep her till I'm dead.  Hopefully a long time from now (55)!
Thanks,
Farmer_John
Reply #1 on: August 04, 2022, 06:28:14 pm
hydraulic lifters, just like a chevy small block!
"It's not what you know, it's how well you reference what you don't"
"Ain't no hill too high for a mountain climber"
Words to succeed by...
Keef Sparrow
Reply #2 on: August 04, 2022, 08:35:40 pm
No adjustment needed - unless they go wrong, which I believe has been known to happen but is rare. I think regular oil/filter changes are more important with hydraulic tappets though to keep them working properly.
Past: CB125-T2, T500, GT500, Speed Triple, 955i Daytona. Now: Royal Enfield Bullet Trials 500
Carl Fenn
Reply #3 on: August 04, 2022, 09:20:44 pm
No that’s the one good thing about hydraulic valves no need for any adjustment self adjusting.
Rad Rich
Reply #4 on: August 05, 2022, 04:40:20 pm
Thanks for the info Gentlemen!  Hope we all have a great weekend and turn some wheels.
ssrealty
Reply #5 on: August 15, 2022, 03:06:46 am
Does the 2020 last year model also have hydraulic valves and require no adjustment?
Haggis
Reply #6 on: August 15, 2022, 10:51:48 am
Yes, all the 500 uce efi engines use hydraulic lifters.
Off route, recalculate?
Reply #7 on: August 15, 2022, 02:11:59 pm
Is there a preload adjustment on these lifters?
Haggis
Reply #8 on: August 15, 2022, 05:14:03 pm
Nope. Not that can see anyway.
I think they have a max travel of around 50 thou as well.
GlennF
Reply #9 on: August 16, 2022, 02:54:17 am
Never had to mess about with hydraulic lifters even when storing bikes for long period. Even if they stick they seem to settle down pretty quick once your up and running.
What I DID have to replace after long (several year) storages was a couple of cam chains.  But the Bullets do not have a cam chain so no risk of issues there.
Silverback
Reply #10 on: May 13, 2023, 05:40:40 am
I have 2012 classic 500 chrome.
If it has hydraulic valves then what's the tappet cover for?
What is the ticking sound like valves need adjustment?
Sounds louder after long hot ride in this 95 degree heat Texas desert.
2011 uce classic 500,  carb converted and trails bars.
Haggis
Reply #11 on: May 13, 2023, 09:10:55 am
No idea why the kept the tappet cover?
There is nothing behind it that needs screwing or adjusting.
Maybe easier access when fitting the lifters?
Or, just a styling thing to look old.
Anyway, just below the lifters you have the inlet and exhaust cams. They need the backlash between the gears adjusted to keep them quiet.
Sounds just like loose tappets, worse when hot.
Silverback
Reply #12 on: May 13, 2023, 04:21:24 pm
Cool thanks. Sounds like I need to adjust back lash.  Appreciate the quick response.
axman88
  • Vintage Motorcycle Fan
Reply #13 on: May 13, 2023, 04:35:33 pm
Just speculating, but maybe this is the access point for the side pull cores that are used to mold the lifter channels?  That's a complicated mold.
Silverback
Reply #14 on: May 13, 2023, 11:20:16 pm
No help locally as they don't know anything about the uce engine. Just the new j engine.
I am having trouble finding any info via manual on this procedure.  I did find this on the you tube.  Any help would be appreciated.  It doesn't seem as though he removes rocker arms.
https://youtu.be/ccpaq3agnGo
« Last Edit: May 13, 2023, 11:22:57 pm by Silverback »
