Thanks again AzCAL for your thorough response, and the rest of the audience for their loud sounds of approval
- needless to say yesterday was a day filled with optimistic exuberance so terminology wise I may have construed a couple of things.
Took it up my driveway and back last night, it started pouring and it felt like I was back riding in Pondicherry India again dodging giant snakes on the red earth backroads.
From what I gather, the clogged needle jet was the root cause of not starting - A clipped strand of wire brush made simple work of whatever had formed in there.
Finding a 10 micron fuel filter was a bit of a quagmire as it seems in these days of search engine optimization, manufacturers, and resellers often leave out this information. I believe this is the correct type even though it specifies for EFI applications - unless anyone has a better option.
Fuel line diameter of 5/16" OD which should fit 1/4" ID if I'm not mistaken?
https://www.holley.com/products/plumbing_an_fittings_and_hose/hose_ends/vapor_guard/parts/731155ERLCarb wise theres a few lingering issues - i'm having intermittent overflows which from @AzCal's notes are likely issues with the
float needle & float needle seat
Here is it together on my bike working as I believe it should...
https://youtu.be/IuHIcnz5JBASince I'm pulling apart the float bowl a fair amount, both of the seals I bought new have swelled larger than the original size making them difficult to replace and seal, is this the wrong rubber or normal behavior for o ring seals + gas. (see image) these gaskets are from Hitchcock's.
Can't seem to get the idle to be in a happy spot from initial cold -> warm, is the choke valve popping on its own back to its "off" state normal behavior or does that indicate that there is too much of a vacuum?
Additionally I think it may be time for a new throttle cable as the end of mine wants to twist out of its cradle.
I'm going to fiddle with this today and see if I can get it to a more happy place.
At one point I had it kickstarting yesterday, but its been a bit more finicky since - and I hear you all on the estart not being kind on this bike, so hopefully this tuning will make that simply for traffic lights.
After reading through the Snidal manual - his recommendation for these bikes is 20w50 oil however my RE service manual states 15W40. Recognizing that the proper type of oil that should be used is a topic that will end friendships, and potentially ignite WWIII. I'm in new England and its not particularly hot and in a few months will start getting down to temperatures I care not mention. For a clean flush I assume this is sage advice? and I will probably change it before 1000mi service to ensure nothing is shaving itself to bits. For now I used mobil synthetic 4 cycle 20w50. Will likely change it to 15w40 as the season gets a little cooler. Haven't added anything to the gearbox yet - thats next on my list of things to check.
Tooseevee can you elaborate on this anecdote
Use the Q-Tip trick on the seat.
does that pertain to putting the float valve under the microscope? I wish I had my grandfathers illuminated magnifying glass on a stand for this one!
Tire question - I put in IRC HD tubes, as everyone has always told me that anything less is just asking for trouble, has anyone had any issue with the extra weight / mass or am I overthinking it?
I had a look at my valves yesterday and my understanding is any wobble in its rotation is enough to warrant replacement. (see video)
https://youtu.be/40EFgdT2GCc Thanks as always
