Author Topic: Booster plug  (Read 2984 times)
dlapierre
on: April 17, 2021, 03:18:41 pm
I installed one on my Himalayan yesterday. A bit of a fiddly job to install it, but it does indeed make a difference. Not so much power-wise, but the acceleration is smoother, it idles better, and seems less reluctant to run at 4k rpm and better.
Without it, the bike seemed hungry for fuel at those engine speeds. Not any more.
I think it is a good addition to this bike.
Toni59
Reply #1 on: April 20, 2021, 07:45:36 pm
Thanks for the feedback - it’s still on my wish list... ;)
Regards
Toni
Enfield Pro
Reply #2 on: April 22, 2021, 01:06:51 am
Regards
Toni
When you decide the time is right they are available in the U.S. If you know where to look.   :-X
Tim
2009 G5 Military W/Sidecar
USCA #9136
REOC Member
longstrokeclassic
Reply #3 on: April 22, 2021, 04:41:25 pm
Wouldn't increasing the TPS voltage output would achieve similar gains but for no outlay?  It's made a tangible difference to previous EFI models, can't see why the Himmy would be an exception.
« Last Edit: April 22, 2021, 04:43:34 pm by portisheadric »
Never underestimate the value of improved combustion efficiency and reducing parasitic engine and rolling chassis losses.
viczena
Reply #4 on: April 22, 2021, 08:15:19 pm
No. It just changes the zero point of the throttle.
www.enfieldtech.de
Harley CVO EGlide, Boss Hoss 502, BMW 1200 RT, Harley Panhead , Harley Davidson &Marlboro Man Bike BD2, Royal Enfield Trials, KTM EXC 500. And some more.
Toni59
Reply #5 on: April 23, 2021, 05:00:47 am
How would one simply increase the tps voltage output?
Wouldn't that just be "turning the throttle faster? Or do you mean actually increase the voltage beyond the stock range?
Regards
Toni
viczena
Reply #6 on: April 23, 2021, 05:46:56 am
The TPS is just a potentiometer. The max voltage is provided by the ECU.
www.enfieldtech.de
longstrokeclassic
Reply #7 on: April 23, 2021, 09:48:12 am
The ECU provides a predetermined amount of fuel for a given throttle position. If the ECU believes the throttle plate is open wider than it actually is because the TPS output voltage has been increased at any [all] throttle plate positions then more fuel is supplied for the same amount of air so the bike runs richer than normal.  Just wondering why this method hasn't at least been tried when it's worked on EuroIV Enfield engines quite successfully. I didn't know if EuroV now had the  TPS unit fixed in one position to avoid making any changes which would improve the running of the engine but increase unwanted pollutants
« Last Edit: April 23, 2021, 10:26:26 am by portisheadric »
longstrokeclassic
Reply #8 on: April 23, 2021, 10:25:19 am
https://www.youtube.com/watch?v=BNYGt2RW8pM&t=12s
I've found 0.63v is a  good compromise between better running and ruining economy!
viczena
Reply #9 on: April 23, 2021, 11:16:25 am
The next thing the EFi does to provide stable idle is to readjust to the lowest TPS voltage it gets over time. The adjustable voltage of the TPS only affects idle mixture. It is somehow like the idle mixture screw on a Carb.
It has nothing to do with delivering more or less fuel in other rpm ranges.
« Last Edit: April 23, 2021, 11:46:50 am by viczena »
www.enfieldtech.de
TrianglePete
  • U.S. Spec RE parts & THE FIN intake.
Reply #10 on: April 23, 2021, 11:35:37 am
Don't forget the MAP sensor..   That seems to have the greatest effect when changing parts.
Good discussion   It covers the EFI models.
Thanks
viczena
Reply #11 on: April 23, 2021, 01:19:57 pm
Fiddling with the MAP sensor is a little more complex.
There are two ways a EFI could react to changes of the driver. The simplest ist called alpha-n.
Alpha stands for the angle of the Butterfly in the manifold. n for the rpm. So if I turn the gasgrip, the Butterfly opens and the TPS (Throttle position sensor) sends the new angle to the EFI. The EFI looksup in a map, how much gas should be injected at the current rpm, and good we are.
The other method is Speed density. For this we need a MAP (Manifold air pressure) sensor. It measures the ambient air pressure before we start the engine. Then it measures the changing pressure inside the manifold relating to ambient pressure while we turn the grip. The changes are most pronounced in areas, where we have a lot of throttle movement. So in low speed. In high speed the Throttle is nearly all open all the time, so the pressure difference is low. And then unusable as a sufficient sensor signal. The MAP sensor indicates the load of the engine. More load means more gas necessary. The ECU looksup in a map, how much gas it has to deliver at this specific load.
The load is different, if you pull the trigger and have large alpha differences in low gear  or in high gears. Or driving on a plane road or climbing a mountain pass.
Both philosophys work best at their specific range. Speed density is good for low and crusing speed, as the pressure differences are big. Alpha-n works best at large throttle openings, where the pressure differences are low, but the change in throttle position is still a valid data.
So the Keihin ECU does exactly that. It works with speed density in low areas and switches to alpha-n in higher areas.
What about fiddling with the map sensor. One could think that by changing the voltage output of the map sensor would change the mixture in lower/cruising areas. That is not the case. First of all the MAP sensor just measures differences to the first ambient pressure of the not-running bike. So if I change the voltage, it would just measure another ambient pressure and the changes would be equal.
If I fiddle more and change the voltage after the bike runs, it would work for a while. But the EFI remeasures the ambient air pressure while running. This allows the engine to adapt to height changes while driving up a mountain. This measurement is done at a preset angle of the crankshaft, where the MAP pressure is most likely the ambient pressure.
There were aftermarket devices on the market which fiddled with the map sensor data. But they were expensive and not as effecticve as the simple Booster Plug devices.
It could be that another MAP sensor with a changed characteritic could make a differnece, but that depneds on the EFI programming. And as far as I know all MAP sensors are mass produced and quite equal.
When I tune the Keihin EFI with a powertronic or eual device, I dont have to think about what system is used, the EFI tuning system presents me an calculated value (sometimes called FTC ore otherwise) that combines both methods to a single Load-value.
Lemma1:
The easiest fix for more fuel in the whole rpm band would be a 10% bigger fuel injector. I have done it on several bikes. But it only works in Open-Loop operation (no Lambda sensors).
Lemma 2: When you use overpressure systems (Turbocharger or compressor) you have to have an Alpha-n regulation.
« Last Edit: April 23, 2021, 01:41:27 pm by viczena »
www.enfieldtech.de
TrianglePete
Reply #12 on: April 23, 2021, 01:37:16 pm
Excellent explanation ...   So the MAP sensor acts like a power valve in an auto carb.
It seems that just changing mufflers or air filter (all owners seem to do it ) throws off the map sensor.
Making the bike run rich ?????
viczena
Reply #13 on: April 23, 2021, 01:44:02 pm
Not exactly, depends more on the values in the VE Map.The dependencies of air pressure changes and more air volume is not simple. Normally if you open up air filter and exhaust the mixture gets lean.
It could be different in multicylinder cars, where the changes in MAP pressure in the manifold is more equalized.
« Last Edit: April 23, 2021, 01:47:13 pm by viczena »
www.enfieldtech.de
TrianglePete
Reply #14 on: April 23, 2021, 02:47:59 pm
Seems like the last time I changed to free flowing muffler.
The pipe turned black and so did the plug.
