Author Topic: Front Brake Issue. Missing bolt?  (Read 2904 times)
RE-Memphis
  • New Englander in Memphis
  • Surprise, machine gun, and vanish.
on: May 21, 2013, 12:20:34 am
Hi,
On the ride home the front brake began grinding. I stopped and checked. It felt loose but otherwise ok. I was able to ride home. On the center stand with the front tire raised the tire will spin freely with a soft rubbing noise from the brake.
Take a look at the attached pictures. I can't visualize how it's supposed to look but it seems like I'm missing something. Pictures attached.
Am I missing a bolt? If so a picture/description/part number of what I need to replace it please!
Or am I over-thinking it and just need to tighten the two mounting bolts?
Thanks in advance for your help.
2012 Royal Enfield C-5 Military
2010 HD Dyna (Sold & hated it)
2008 HD Nightster (Traded with regrets)
1972 Triumph Bonneville (Still kicking myself in the arse for selling her)
whoguy
  • Hi... I love all things Beautiful...
Reply #1 on: May 21, 2013, 12:34:53 am
Definitely something has fallen off. Should look like my brake below!!!
To ride or not to ride... That is the question!
mplayle
Reply #2 on: May 21, 2013, 12:39:49 am
Went out and looked at the front brake on my C5.  Yes, you appear to be missing a part.  There should be a guide pin on the end of the bolt visible in your pictures - it extends into that notched 'ear' on the opposite pad.
Neither of my paper catalogs show the part.
The pdf "Parts list" I have does not list it as an individual item, but part of the "Mounting Bracket Assembly" (p/n: 560583).
RE-Memphis
Reply #3 on: May 21, 2013, 01:03:58 am
Thanks for the photo! And the feeling that I'me over cleaning my bike :)
RE-Memphis
Reply #4 on: May 21, 2013, 01:05:11 am
Ok. Damn. Not a simple bolt. I'll have to hit up my local shop tomorrow!  Thanks.
Reply #5 on: May 21, 2013, 01:28:42 am
Because the missing part is a part of the Mounting Bracket Assembly,  if the motorcycle is still under warranty, replacing the entire assembly should be covered.
It is not meant to come apart and the fact that it did makes it a defective part the way I see it.
RE-Memphis
Reply #6 on: May 21, 2013, 01:35:16 am
I agree. I've been pretty good about checking the mounting bolts, etc. for tightness.. I hadn't thought to start on the assembly.
I have an Enfie shop nearby. We'll see what they say.
no bs
Reply #7 on: May 21, 2013, 04:03:02 am
definitely a safety issue. hope you're still covered under wa
rranty. made me go out and put an eyeball on mine! not to mention a wrench. so far so good.
ROVERMAN
Reply #8 on: May 21, 2013, 08:18:06 pm
+1 to all. Please keep it parked! Until a replacement is found.
Craig McClure
  • Riding over 50 years
  • "No Future In Getting Old"
Reply #9 on: May 21, 2013, 09:03:06 pm
Definately don't ride it! I crashed & totaled my Kawasaki W650 last year due to a front disc grabbing & locking up, going into a corner. Lucky to crawl away from that one, with only a ruptured rotator cup (Left shoulder/arm). Never had a problem with front drum brakes for 40 years. Discs can be potentially dangerous!
Best Wishes, Craig McClure
RE-Memphis
Reply #10 on: May 21, 2013, 11:57:51 pm
Yeah it's parked. I have both the local shop in Memphis and one further afield seeing if it's a warranty item or not. Mike's Cycle out in Waynesboro is even looking to see if they have an extra part laying around the shop that they can mail me.
RE-Memphis
Reply #11 on: May 31, 2013, 01:47:40 am
So I started a new thread explaining how in the pursuit of checking if this was a warranty item I learned that both of the nearest (15 and 150 miles) Enfield shops have parted ways with RE for various reasons.
The good news is that Mike's in Waynesboro made the bolt on their lathe and are mailing it to me!
They're big on customer service and I'm glad there are still shops like this around.
Awesome.
« Last Edit: May 31, 2013, 02:28:32 am by RE-Memphis »
Reply #12 on: May 31, 2013, 01:56:21 am
THAT is customer service!
Royalista
  • phaneropter
Reply #13 on: May 31, 2013, 01:57:04 am
Scary event with a lucky ending. Be safe  :)
moriunt omnes pauci vivunt
