Reply #6 on: October 06, 2021, 03:50:28 pm
Thanks CyrusB, the "loose-in-the-bore" tappet shaft is where most of the noise comes from on my machine too. I can move the heads a fair bit when they are unloaded & replicate the "rap" sound. The metal-on-metal pounding is RPM dependent, at road speed it seems to find a happy spot & quiet down, and is worst at idle. My cam noses seem to have a bit of wear also. Not a problem that money won't solve though, innit?
I was wondering though if the adjustable spindles had any effect on total noise, seems like they might.
Well, the gears would not be inclined to produce a tapping sound. Badly meshing gears would produce a whine or whir kinda sound. But since these gears are so lightly loaded (unless you run a mag) I would look elsewhere. How you adjust the valves can make all the difference .
As an aside, There is so much oil collected down low in the timing chest that most cam gear noise would be muffled. To get back to the tank the returning oil has to make it all the way up to a 5/16" hole behind the last idler. That is a torturous path, with only gear windage and crankcase pressure to help it along.
« Last Edit: October 06, 2021, 04:15:36 pm by cyrusb »
Logged
