I have got it in my head to play around with a carb I came across by accident. It's called a Pekar & I don't know if that's a brand name or a nickname or something else.
The story I get is that this is a Chinese copy of a Russian carb that has been used on URALs in many foreign countries going way back to the early days of URAL. It's a 30mm so is smaller than my TM 32.
Has a round slide with 5 groove needle. It has a tickler, but I'm told it has no Pilot Jet although it looks to me that there IS another jet in there (I have it totally apart at the moment). He says that only the Main Jet can be changed & I got a Huge array of main jets with the carb. Of course it has a regular Mixture Screw & Idle Speed Screw. It appears as though my throttle cable will hook right up no problem. Some tweaking expected, of course. There always is
The man I got it from says he has put them, with success, on single BSAs, Triumphs & REs up to 500 & dual setups on larger twins. I just wonder if the increase in flow that my ACEhead has, if it's even worth the effort to try it & go through all that tweaking.
I realize that with a bike like, say, a 650 URAL, each carb would only be dealing with 325cc so it might be perfectly OK. I have a feeling my engine might be starved a bit. I might be detuning it a bit too much.
Does anyone have personal experience of this carb? Not "Well, a guy down the street says" experience. Or even HEAR of it?
Ace: If I was to send you this carb, is there a way to evaluate it (flow test?) & just say it ain't worth the trouble on my particular engine with such an increased flow from a stock AVL. I could easily do that.
I'll get a couple pictures later.
