You do right. There is such a thing as walking away and living to fight another day, it's no fun if you finish up with you or the bike broken. I remember sitting at the start of a section on my first trial, looking at a near vertical 20 foot drop-off into an abandoned quarry and thinking "It's pure luck if it's me or the bike that arrives at the bottom of that first. I've got work on Monday." I took the 6 points and moved on. After the trial, I noticed 6 other entrants had done exactly the same, most of whom were on drum-braked Brit-iron.
It constantly amazes me what my Bullet will drag itself up and across, especially if it is stony or gravelly. I find my main difficulty is on sections of deep mud or wet, soggy grass where I can find absolutely no traction. I've failed to even get moving off the line on a few sections like that. My last trial re-ran a couple of slithery, muddy woodland sections later in the day (after 60 bikes and 40 cars had been over them in the morning leaving it as about 6 inches of watery loose mud on top of slippery clay) and I simply couldn't get the bike moving, even after dropping the tyres to 5psi. In fact I struggled to walk it back off the section.
Any tips for riding a bullet in slithery mud? I think tyres don't help because I'm pretty much limited to 19 x 3.50 Heidenau K67s on the rear unless I want to fabricate a new swingarm. You can't really use super-sticky rubber on long distance trials because there's usually 80-150 miles of road navigation between sections. That said, a guy on a ridgid matchless 500 cleaned both the sections I never got off the line on so technique is definately the main factor.
The best thing about completing a trial on an Enfield bullet is even if you're last, you still win.
