getting the oil level correct on these machines does seem to be problematic at first, it is important that the bike is on a level surface when its on the top/centre stand, just slightly out of level can mean the difference between it looking overfilled or empty!, I found on mine that on a level surface the oil level was correct so i measured the amount that drained out (unfortunately I can't remember what the amount was,) I then put the same amount of fresh back in and when Ive checked since it is always ok, there doesn't appear to be much between top and bottom level marks either.
