Has anyone got a step by step guide in how to fit Hitchcock's PART No. 92784/340 - REAR SHOCK ABSORBERS 340mm (20mm Shorter than std), PAIR, OPEN CHROME SPRINGS, 650 Interceptor+650 GT - Hagon Shock Absorbers.
Basically, the hole dimensions on the Original RE Shocks is 360mm.
So, If I remove these how do I then fit the shortened (By 20mm) 340mm Hagon Shocks.
After I remove one of the original shocks, I would have to compress the Suspension somehow, but how would you do this?
Any help would be greatly appreciated.
Many Thanks,
Pete.
