So I'm in the process of re-assembling the rear wheel. Fitted the new bearings but inserting the axle was difficult as it seemed to catch on something. Seemed the spacer was damaged a bit when removing old bearings. Plus the axle itself was sort of pitted so cleaned cleaned it and the inside of the axle hole with some 1200 wet and dry and now works ok.
Tried my hand at lacing the wheel. I had to assemble and disassemble a few times before I got it right but with the help of some other enthusiasts, its done. I now know for next time - keep the left and right, inner and outer spokes together. Should be 4 piles. I just bunched them all together without paying attention...Wrong. Anyway, I learned the difference between inner and outer so it's together. I'm just tensioning the spokes up now, then get onto the front wheel.
Regards
Tv
