Oh yeah I’m not expecting it to be anything more than what it is. It’s practically farm equipment lol (my friends refer to it as a tractor).
But it seems to me it should be perfectly capable of what I’m asking from it. Winding hilly back roads, a touch of highway, and a little “city” driving.
The speed on the highway is 55mph, so of course everyone drives about 65. I do that for about 10 mins straight out of the driveway so I let it warm up well before taking off.
Then it’s 5 minutes ride through a small rustic town with about 3 red lights and a beautiful stroll by the lakeside with a speed limit of a mere 30mph, which the two town police strictly enforce.
From here it becomes winding hilly country back roads, not much elevation but enough for a good view. This is the longest stretch of my journey that last approximately 20-30 minutes and has a speed limit of 45-55mph, so most people drive 50-60mph. There’s some really sharp turns requiring 25mph, a long straight or two where I get up to 65, and plenty of time spent throttling up and down and changing gears as the curves come quickly. I tend to spend most my time in 4-5th gear here at 45-60mph, so around 52mph average probably. Lots of throttle input out of corners. I hardly ever reach WOT even on the straights, but I am often around 3/4 throttle when cruising in 5th at 60-65mph.
Then my journey ends as the back roads empty into a long straight that turns into increasingly shortening red light stops in the major town/city. It’s not like a city with big buildings or like a major downtown setting. No, it’s more like a large college town. But the outskirts of the town, so plenty of intersections a 45mph speed limit (though everyone drives about 50), and typical business buildings- groceries, fast food, doctors offices, that sorta stuff.
And then im in the neighborhood where the shop is located, with a beautiful view of the Smokey TN mountains as I make my way through the neighborhood roads.
I should really get a gopro and film it, its a beautiful ride.
But it is quite a long ride, it takes me anywhere from 45 minutes to 1 hour, its 32 miles one way. The bullet should be more than capable of this journey I think. I do have two other motorcycles, granted ones in pieces, I just had the frame powder coated and all I've done is reinstall the engine, forks, and swing arm, basically just to get it to roll around the shop. I have rebuilt the carbs though and have all new parts just waiting to go on it, so if its a interstate capable bike I was after id get my butt in gear to finish putting it together. It's just a little Honda CM400 from the 1980s, but it can reach about 100mph or so. 43BHP out of a parallel twin. But honestly I'm just having far too much fun with the Royal right now. It really is a blast to ride and tinker with. Sometimes I do wonder if I am pushing it too hard on this journey to commute to work. It seems I'm right on the edge always at 60-65mph. It can hit 80 but anything over 70 feels like its straining and I am probably close to floating valves at that point and whatnot. Like I said, im not just screaming along for an hour at WOT but I get close sometimes on those straight aways. I think its probably fine, but a different sprocket geared for even just an extra 5mph on the top end might be ideal for what I do with it.
Other than that I usually just ride around the windy country back roads out here around the house where the speed limit is usually 45 but honestly that feels too fast, the corners are sharp and quick, practically short switchbacks.
As for the "sealant" on the gasket blow out, no. It's hard to see in the photo but the black in the middle of all that red gasket maker is the black gasket (oem I assume) that has pushed its way out of position and about half of its thickness is protruding outside the cover causing a slow leak.
Admittedly, I don't know what you mean when you say:
I think the main jet (3/4 +) is the best place to start when tuning by the carbon ring, get it low on the center insulator and then the needle jet/needle (2/5- 3/4ish) combo will be next.
What is meant by 3/4+ and 2/5-3/4ish?
