Yeah no points to worry about here, although I like the archaic tech, instead I just have to worry about the pickup on the crank being out of time from the factory per our other thread lol.
Yeah so I bought the bike non running, tanks been cleaned, carbs been sonic cleaned, fresh oil change twice over to ensure I got all the moisture out since it sat for a few years, shit looked like chocolate milk lol, spark plug is new as well, although the plug keeps throwing me off trying to read it, its like its too rich and too lean at the same time, I don't get it. The ceramic by the electrode is still pure white after 400+ miles indicating a too lean condition but the outer edge is heavy with black soot indicating a too rich condition.
Well I take that back, this plug probably only has about 200 miles on it. I changed it out because I pulled the baffler in the header pipe and upped the jet size too large and killed the NGK plug I had in it. This new autolite brand plug I fear might be burning hotter- the ground strap is clean about 3/4 of the way, it should be more like half if its the correct temperature, if I understand correctly, but thats a whole other thread I have going on about my super blue exhaust pipes that I can't seem to figure out... perhaps I should still be running the stock jets since I only removed the baffle or maybe I need to get a high flow air filter and mod the box idk...
At any rate, for now, this problem seems to have resolved itself. Im sure ill post here again if it happens again or I find any indication of what's causing it.
Thanks y'all.
