Update time
Bike is running and we went out for some diagnostic laps around the block.
Still have some issues.
1) Surging...
The chain was a bit loose so we thought that might be it.
Nope
Very noticeable cruising in 2nd gear.
Plug looks on the rich side of acceptable but maybe it is leaning out over 2000 RPMs???
Thinking about moving the needle up one notch (on center notch now)
(Everything bone stock now including all carb parts, exhaust & filter)
2) Questionable charging system
I'm going to look into that one & make myself more knowledgeable after doing some forum searches.
Disconnected headlight for some around the block riding and everything was OK for now but I have suspicions that something isn't right. (3 wire stator & stock R/R)
3) Front brake sucks...
Dad said it was my windmill to tilt because he doesn't care about it.
Ordering new pads from H and will try them.
Will report findings later.
Observations....
1) The clutch is pretty darn good.
Not Interceptor good but I have no issues with it.
During my searches, I read a lot about slipping and folks advising to shift to neutral for long lights.
I've held it in for minutes and it didn't get grabby or feel like anything was amiss.
2) The rear brake is suprisingly good.
I'm impressed. No reason to mess with anything there.
Things are coming along.
One thing to note.
It will only start w/ the enricher on. It prefers it on even when warm.
